Creating MASK from vect / Problems with v.spag
Stephan Eickschen
eicksch at uni-muenster.de
Wed May 6 05:48:44 EDT 1998
Hi-
thanks to all who have answered my request for help! Malcolm - your
way seems to be the best. Unfortunatly, v.spag hangs on my system (as it
is mentioned to be possible in the GRASS Ref. Man. at v.spag / BUGS...).
I am running GRASS4.1.5 on a SGI system (uname -srm IRIX64 6.4 IP27).
It is the binary release from ftp.funet.fi (that is the same as
ftp.cecer.army.mil). >file v.spag< results in
> ELF 32-bit MSB dynamic executable MIPS - version 1
Does anybody have an update I could use (if possible as binary)?
I need the capability of v.spag to create nodes for crossing lines. It
hangs at
> Reading Vector file.
> 100%
> Cleaning lines less than thresh
> Identical lines check and Line intersections
Does anybody have experience wilth v.spag of GRASS 4.2X with Linux, or:
Is there a binary release of 4.2X for SGI?
Thanks in advance for any help,
regards,
Stephan
Stephan Eickschen Tel. : +49 (0)251 83-34704
Westfaelische Wilhelms-Universitaet Fax. : +49 (0)251 83-36100
Institute for Geophysics
Research Unit of Physical Glaciology email: eicksch at uni-muenster.de
Corrensstrasse 24
48149 Muenster
Germany
