xgrass was Solaris and XGRASS 4.2.1
Clifton Wood
cbwood at vt.edu
Thu May 7 16:25:08 EDT 1998
Herve Dreau wrote:
> I dont have Xgrass on my home computer, but at work i compiled grass
> under Linux with the version of Lesstif provided by grass. First I
> have the same behavior than you discribe, I can pass this step by
> passing parameters in command line argument to xgrass (try xgrass
> --help or something like this) for location mapset and database.
> like xgrass -location=leics -mapset=dreau
> -database=/usr/local/grass42/data
Aha!
Now why didn't I think of that? :>
I'll still be mucking with the code to see why the other 2 selection
boxes
don't work when I get some time. I find it counter intuitive to have to
use COMMAND LINE options to do something the interface should use, but
this
works right now as a quick fix!
> My 2 eurocents
A cent saved is a cent earned. Thanks much!
Clifton B. Wood
Programmer/Analyst for Virginia Tech's AGNIS Department
-------------------- Thought of the Day --------------------
windows95 = n. 32 bit extensions and a graphical shell for
a 16 bit patch to an 8 bit operating system originally coded
for a 4 bit microprocessor, written by a 2 bit company that
can't stand 1 bit of competition.
