grass termlib problems - follow up
Markus Neteler
neteler at geog.uni-hannover.de
Mon Apr 26 06:41:00 EDT 1999
suggestion: use libncurses instead of libcurses.
This might help. But you have to remove all GRASS libraries
already created before restarting the compilation process.
libcurses is old, libncurses is the successor.
Good luck!
Markus Neteler
> The sys op followed the recommendation and commented out termlib from
> the main make file. We're not quite there...
> Well, it seemed to take longer than before to fail, but I still have one
> of the problems we had before: if I get rid of the TERMLIB line, it ends
> up with some undefined symbols.
> solaris2.6/libvask.a -lcurses -lm
> Undefined first referenced
> symbol in file
> tgetnum /usr/ucblib/libcurses.a(cr_tty.o)
> tgetstr /usr/ucblib/libcurses.a(cr_tty.o)
> tgoto /usr/ucblib/libcurses.a(cr_put.o)
> tputs /usr/ucblib/libcurses.a(endwin.o)
> tgetent /usr/ucblib/libcurses.a(cr_tty.o)
> tgetflag /usr/ucblib/libcurses.a(cr_tty.o)
> ld: fatal: Symbol referencing errors. No output written to
> /usr/local/grac/bin/main/inter/d.3d
> *** Error code 1
> make: Fatal error: Command failed for target
> `/usr/local/grass42/etc/bin/ter/d.3d'
> GISGEN failure at STEP: src/display/d.3d
> Any thoughts?
> Thanks for the previous response - we're almost there,
> Maribeth
> >From: "Micron.Net" <bahoover at micron.net>
> >To: <grass at cecer.army.mil>
> >Subject: Re: grass termlib problems
> >Date: Tue, 20 Apr 1999 21:33:13 -0600
> >Looks like you are using solaris. Comment out the comment out the TERMLIB
> >statement
> >#TERMLIB = -ltermlib
> >this should work.
> >attached is my header file for solarisx86 2.6. It should also work for the
> >sparc version of solaris
> >-----Original Message-----
> >From: Maribeth Milner <mmilner1 at unl.edu>
> >To: grassu-list at cecer.army.mil <grassu-list at cecer.army.mil>
> >Date: Tuesday, April 20, 1999 7:10 PM
> >Subject: grass termlib problems
> >>Can anyone help us with the following problem?...
> >>If we specify "-ltermlib" for the TERMLIB option while running the setup
> >>script (the relevant part of the "head" file is below), then we get a
> >>compiler error telling us that there are multiple definitions for
> >>Def_term. However, if we leave that option blank, we get "undefined
> >symbol"
> >>errors. The multiple definition errors are pasted below.
> >>TERMLIB = -ltermlib
> >>CURSES = -lcurses $(TERMLIB)
> >>MATHLIB = -lm
> >>Compile error:
> >>/usr/ucb/cc -s -o /usr/local/grass42/etc/bin/main/inter/d.3d OBJ/main.o
> >>OBJ/threed.o OBJ/transform.o OBJ/clip.o OBJ/get_range.o OBJ/check_opt.o
> >>OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o
> >>/home/jenny/src42/src/libes/LIB/libD.a
> >>/home/jenny/src42/src/libes/LIB/libdisplay.a
> >>/home/jenny/src42/src/libes/LIB/libraster.a
> >>/home/jenny/src42/src/libes/LIB/libgis.a
> >>/home/jenny/src42/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
> >>ld: fatal: symbol `Def_term' is multiply defined:
> >> (file /usr/ucblib/libcurses.a(curses.o) and file
> >>/usr/ccs/lib/libtermlib.a(setupterm.o));
> >>ld: warning: symbol `ttytype' has differing sizes:
> >> (file /usr/ucblib/libcurses.a(curses.o) value=0x32; file
> >>/usr/ccs/lib/libtermlib.a(setupterm.o) value=0x400);
> >> /usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
> >>ld: fatal: File processing errors. No output written to
> >>*** Error code 1
> >>`/usr/local/grass42/etc/bin/main/inter/d.3d'
> >>TIA,
> >>Maribeth
> >>Attachment Converted: "d:\eudora\attach\solaris"
