Scanning a map that has been folded? (NOT GRASS SPECIFIC)
Bruce_Byars at baylor.edu Bruce_Byars at baylor.edu
Tue Nov 16 15:46:59 EST 1999
Good suggestion David,
But be sure you place a towel between the iron and the
map (like a bath towel).  You wouldn't want your map to
scorch or burst into flames.  :-)   Hope that helps as well.
Bruce
David Irving wrote:
> "Robert L. Sandefur" wrote:
> > Hello -
> > This is not grass specific but has anyone gotten the fold creases out of a folded map before scanning? I have several folded maps to scan and am thinking of ironing  them but I would consider  other options (including software). Suggestion for iron settings are also appreciated (steam or dry high or low) Searching the net returned no hits.
> > Thanx
> > Bob Sandefur
> > Principal Geostatistician
> > PAH
> > rls at pincock.com (primary)
> > rlsandefur at aol.com (secondary)
> > 303 914 4467 v
> > 393 987-8907 f
> people who fold maps should be dropped off a cliff.
> seriously, if you can't get another, unfolded, copy of the map, ironing is probably your best option. using a steam setting (not too hot) would expand the paper fibres, and help get rid of the folds.
> david
