Copmiling GRASS50beta3
    Hanno Saks
    hanno at lv.parnu.ee
    Tue Sep  7 07:02:16 EDT 1999
Hi!
I'm tring to compile and after ./configure I get this:
/root/.bashrc UNIX_BIN=/usr/local/bin SCR=/usr/local/grass5.0beta
GISBASE=/usr/local/grass5.0beta MACHINENAME=grass.lv.parnu.ee /bin/bash
scr/CMD/generic/CREATE_GMAKE.sh
/bin/bash: /root/.bashrc: Permission denied
make: *** [pre-install] Error 126
What's up?
Hanno
> -----Original Message-----
> From:	Agustin Lobo [SMTP:alobo at ija.csic.es]
> Sent:	Tuesday, September 07, 1999 12:04 PM
> To:	grass at cecer.army.mil
> Subject:	Re: Box Counting Method
> I did something similar to study the sprectral response of
> a high reolution sensor for each cell of a coarse resolution
> sensor.
> I just made an script (I think that I actually contributed to Markus N.)
> that produces a numbered image, i.e., like r.clump but each pixel has
> an individual integer value.
> You could run a similar process for each given resolution and create a
> suite of rasters (numbered.1, numbered.2, numbered.3 ...) that would
> match as:
> numbered.1:
>  1  2  3  4  5  6  7  8  9
> 10 11 12 13 14 15 16 17 18
> 19 20 21 22 23 24 25 26 27
> numbered.2
>  1  1  2  2  3  3  4  4  5  5
>  1  1  2  2  3  3  4  4  5  5
>  6  6  7  7  8  8  9  9 10 10
> Then you select the resolution of your fracture maps
> (0: no fracture; 1: fracture; if you have different types
> of fractures, just add more categories) and use
> r.stats with each numbered.x map and your fracture map,
> to obtain, for each numbered.x, a file with 2 columns:
> numbered.1  fracture
> 1             0
> 2             0
> 3             1
> 4             1
> 5             6
> etc.
> Export to your stats program and count the number of "1"
> for each numbered.x. From this series you can calculate
> the fractal dimension.
> It might seem complicated, but it's not.
> Agus
> ****NOTE NEW PHONE NUMBER*****
> Dr. Agustin Lobo
> Instituto de Ciencias de la Tierra (CSIC)
> Lluis Sole Sabaris s/n
> 08028 Barcelona SPAIN
> tel 34 93409 5410
> fax 34 93411 0012
> http://pangea.ija.csic.es/alobo
> On Mon, 6 Sep 1999, Michael Schulz wrote:
> > Dear List!
> > Together with a diploma student, we are trying to use GRASS to
> > perform calculations with the Box Counting Method. The box method is
> used
> > here to measure the fractal dimension of the spatial and scaling
> > distribution of fractures.
> > A sequence of grids, each with a different cell size is placed over maps
> > of fracture traces and the number of cells intersected by the fractures
> > is counted.
> > We used scanned maps of the fracture traces, imported them into GRASS
> and
> > tried to run r.reports on the same mapset with varying resolutions. this
> > did not work. We thought about using r.mapcalc to do some kind of
> > neighborhood analysis, but the problem seems to be the varying cell
> sizes.
> > Is it possible to use r.mapcalc within one location but different
> > resolutions of raster maps ? Could it be done with several locations (
> > r.mapcalc takes input from location 1 with res 1 and analyzes this grid
> > with neighborhood-sizes of location 2 with res 2 and writes the result
> to
> > location 2 ) ?
> > Any comments or ideas would be appreciated !
> > Cheers, Michael
> > Michael Schulz
> > Christoph-Mang-Str.5       Geologisches Institut
> > 79100 Freiburg             Universitaet Freiburg
> >                            Albertstr. 23b
> >                            79104 Freiburg
