problems with ps.map in GRASS5beta8
chiara sboarina chiara.sboarina at katamail.com
Mon Aug 21 03:57:30 EDT 2000
Il Sat, 19 August 2000, Markus Neteler ha scritto:
> On Wed, Aug 09, 2000 at 12:09:03PM +0200, chiara sboarina wrote:
> > Hi all,  when I run ps.map it doesn't work and the next message appears:
> > ERROR: unable to exec ps.map.new
> > I searched for ps.map.new in grass5.0beta8_linux.tar.gz but the only file I found is  /man/2/ps.map.new.
> > I'd like to know if the bin file of ps.map.new exist in grass5beta8 or if the problem is a bug of ps.map.
> > Thank you
> Hi Chiara,
> sorry for this bug: The module was renamed and we missed to
> correct it internally.
> You can try to overcome the problem by adding a link
> (it will be fixed in the next version of GRASS).
> cd $GISBASE
> cd bin
> ln -s ps.map ps.map.new
> Please tell me if this helps.
> Markus
This link is not enough so I've added symbolic links to all ps.map files in $GISBASE/etc/bin/main and now it works.
Thank you
Chiara
___________________________________________________
Se vuoi un indirizzo di posta elettronica gratuito,
iscriviti a http://www.katamail.com
