AIX 4.3.3
Ulrich Senn
usenn at access.unizh.ch
Mon Aug 21 05:04:19 EDT 2000
Hello!
I try to install Grass4.3 on IBM SP2/AIX 4.3.3 but without any success -
error code see below!
So I' d like to ask you if there is anybody with any experience on
installing both GRASS level 4.3 and 5 on this platform?
Thanks a lot!
Ulrich
error code which comes out with >GISGEN.head:
gcc -s -o HTMLMAP OBJ/connect.o OBJ/Can_do.o OBJ/Color.o
OBJ/Draw_line.o OBJ/Get_w_box.o OBJ/Get_w_line.o OBJ/Get_w_pnt.o
OBJ/Graph_Clse.o OBJ/Graph_Set.o OBJ/Panel.o OBJ/Polygn_abs.o
OBJ/Reset_clr.o OBJ/Returns.o OBJ/Text.o
/rzu/aix/fs2/dist/util/grass4.3src/src/display/devices/lib/LIB/driverlib.a
/rzu/aix/fs2/dist/util/grass4.3src/src/libes/LIB/libgis.a
ld: 0711-317 ERROR: Undefined symbol: .atan
ld: 0711-317 ERROR: Undefined symbol: .fmod
ld: 0711-345 Use the -bloadmap or -bnoquiet option to obtain more
information.
collect2: ld returned 8 exit status
make: 1254-004 The error code from the last command is 1.
Stop.
GISGEN failure at STEP: src/display/devices/HTMLMAP
