r.in.gif: Illegal latitudes
bob at math.umn.edu
bob at math.umn.edu
Tue Feb 1 16:59:32 EST 2000
Howdy.
Using r.in.gif, I am getting a lot of these:
ImageDesc l 0, t 0, w 864, h 310
WARNING: G_set_window(): Illegal latitude for North
Using xv to rewrite the map as a TIFF file, we get:
Reading /var/tmp/pop/gpw.tif...TIFF Directory at offset 0x41648
Image Width: 864 Image Length: 310
Resolution: 1200, 1200 pixels/inch
Bits/Sample: 8
Compression Scheme: None
Photometric Interpretation: palette color (RGB from colormap)
Orientation: row 0 top, col 0 lhs
Samples/Pixel: 1
Rows/Strip: 9
Planar Configuration: single image plane
Color Map: (present)
ERROR: couldn't set cellhd.
The GIF is GIF87, so that is not a problem. Any ideas what I am doing
wrong here? r.in.ascii works fine.
I have grass5.0beta5 on linux 2.2.14.
Thanks for your time.
Adios,
Chris
C.S. Cornuelle
School of Mathematics/MCIM, University of Minnesota
206 Church St. SE, Minneapolis, MN 55455
(612) 626-8930v, (612) 624-2333f, bob at math.umn.edu
Ferventer Vestite
