nviz2.2 question
    Michael A Crimmins
    mcrimmin at net-link.net
    Tue Mar 14 11:37:00 EST 2000
Hi Markus,
Here are the full error messages on my nviz2.2 problem:
GRASS:~ > nviz2.2
NVWISH2.2: error in loading shared libraries: libMesaGLU.so.3: cannot open
shared object file: No such file or directory
This is what happens if I change the first line of the nviz2.2 startup script
to ' : ' instead of ' #! '
GRASS:~ > nviz2.2
/usr/local/grass-5.0b/etc/bin/contrib/cmd/nviz2.2:
:/usr/local/grass-5.0b/etc/bin/contrib/cmd/NVWISH2.2: No such file or
directory
/usr/local/grass-5.0b/etc/bin/contrib/cmd/nviz2.2: /config.tcl: No such file
or directory
/usr/local/grass-5.0b/etc/bin/contrib/cmd/nviz2.2: global: command not found
/usr/local/grass-5.0b/etc/bin/contrib/cmd/nviz2.2: syntax error near
unexpected token `Nv_(T'
/usr/local/grass-5.0b/etc/bin/contrib/cmd/nviz2.2: line 22: `set Nv_(TOP)
".top"'
I originally installed beta6 in a directory called grass-5.0b6, but
reinstalled it into grass-5.0b on suggestion to account for any hardwired
directories.
So I guess it brings me back to the Mesa libraries. The RPMS are in there and
seem to be loaded correctly, but not doing the job. I have tried to stay away
from compiling for as long as I could, but it is time to take the plunge. I
downloaded the Mesa3.1 source code file and tried to follow the directions
provided on the grass site. The problem I run into immediately is that the
make command isn't found. I checked to see if have a compiler loaded and I
have the latest egcs rpm loaded from my last RH6.1 install. This is a linux
problem rather than a grass one, but I would appreciate any suggestions.
Thanks to everyone for their suggestions and thanks for your help, Markus.
Mike Crimmins
Kalamazoo, MI
Markus Neteler wrote:
> Hi Mike,
> I would need the full error message...
> Markus
Type: text/x-vcard
Desc: Card for Michael A Crimmins
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20000314/876a4c4c/mcrimmin.vcf
