[GRASSLIST:2281] problems with grasslinks
jun liu jliu_01 at yahoo.com
Sun Aug 5 18:09:30 EDT 2001
Dear Glynn:
The problems I mentioned before are all solved because
of your help. Thanks again.
Here is the new one.
I try to run the grass command in "gl31.pl" from a
user's webpage, such as "p.select ppm" and
"p.map.new".
"p.select" will work (i redirect its output to a tmp
file), but "p.map.new" or "g.list type=vect" will not
work. I check the error.log and get the information as
" ERROR: MAPSET grasslinks4 - permission denied".
$HOME/$GISDBASE/../grasslinks4 directory is already
set as  777.
I also checked the grass env variables setting and it
seems referenceing correctly. In fact, I can run the
GL script directly from unix terminal (not grass
terminal) and grass command can be executed.
what do I need to do?
Thanks.
--Jun
__________________________________________________
Do You Yahoo!?
Make international calls for as low as $.04/minute with Yahoo! Messenger
http://phonecard.yahoo.com/
