[GRASSLIST:2284] Re: problems with grasslinks
    Glynn Clements
    glynn.clements at virgin.net
    Sun Aug  5 23:39:33 EDT 2001
jun liu wrote:
> The problems I mentioned before are all solved because
> of your help. Thanks again.
> Here is the new one.
> I try to run the grass command in "gl31.pl" from a
> user's webpage, such as "p.select ppm" and
> "p.map.new".
> "p.select" will work (i redirect its output to a tmp
> file), but "p.map.new" or "g.list type=vect" will not
> work. I check the error.log and get the information as
> " ERROR: MAPSET grasslinks4 - permission denied".
> $HOME/$GISDBASE/../grasslinks4 directory is already
> set as  777.
$HOME/$GISDBASE? It should just be $GISDBASE.
Glynn Clements <glynn.clements at virgin.net>
