[GRASSLIST:2288] Re: Making better use of ~/.grassrc5
Rich Shepard
rshepard at appl-ecosys.com
Mon Aug 6 09:38:55 EDT 2001
On Mon, 6 Aug 2001, Markus Neteler wrote:
> I am not sure if you are using the proper variables. The env_vars.html at
> http://www.geog.uni-hannover.de/grass/gdp/html_grass5/env_vars.html
> says:
> XDRIVER_HEIGHT
> [d.mon]
> defines the height of GRASS monitor
> XDRIVER_WIDTH
> [d.mon]
> defines the width of GRASS monitor
> So far MONITOR_HEIGHT and MONITOR_WIDTH don't exist as far as I know.
> Where did you found them referenced?
I'd have to check my saved messages, but someone suggested these as shell
variables. When I export them with values in bash, then open a monitor, they
work. Not having checked for GRASS-specific environmental variables, I just
went ahead and used the same name.
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Making environmentally-responsible mining happen.
