[GRASSLIST:2362] d.profile actually
Kevin Slover
kjslover at nhc.noaa.gov
Mon Aug 20 09:20:54 EDT 2001
sorry, got confuse, I am really using the d.profile command:
am working with the d.profile command, and have gotten it to work for
what I am needed...however, I have a question about it...
is there a way to change the scale?? Ex, I am working with LIDAR data
for both land and ocean, and have heights ranging from -186 to +35...the
scale used gives me that range...however, I do not really care about
anything greater than even -50...is it possible to use a MASK and
"blank" out those depths less than -50??
and secondly, is there a way to get a better picture?? The profiles are
small, and very difficult to read. I have thought about using the
exported file and drawing a profile using a different program, however
that will become tedious with the number that I am needed to look
at...any suggestions for this??
Kevin Slover, Meteorologist/Oceanographer
Tropical Prediction Center/National Hurricane Center
11691 SW 17th Street Miami FL 33165
Work: (305) 229-4456 Fax : (305) 553-1264
e-mail: kjslover at nhc.noaa.gov kevin.slover at noaa.gov
Web address: http://www.nhc.noaa.gov
