[GRASSLIST:2738] Re: i.rectify and image resolution
Markus Neteler
neteler at itc.it
Wed Dec 5 14:34:44 EST 2001
On Wed, Dec 05, 2001 at 03:09:25PM -0300, ulf at mail.zmt.uni-bremen.de wrote:
> Thanks for your answer! Now there is another problem: The rectified
> image seems to be causing problems in the target data set; at least I
> get segmentation faults of d.rast and ps.map. Depending on the actual
> region, the image is printed more or less completely. Do you have any
> suggestions how to track this down?
> Thanks, Ulf
Ulf,
I temporarily had this problem: reason was that the file system
was full. Can you do us a favor and retry, and watch the disk
free status?
You may use
watch df -k
for that purpose (if watch is installed on your machine).
Noter, the temp files are stored in the LOCATION, not in /tmp!
Unfortunately i.rectify doesn't send an error if disk full occurs.
But it silently cleans up after finishing - so the user doesn't
realize the problem.
In my case a cleanup of unused stuff helped. However, please try
again before freeing space - this is the chance to track down
the bug/problem (either to confirm above idea or to point out that it is a
different problem).
Thanks in advance,
Markus
> > I recall having had problems with option 1 (define smallest area).
> > I always check the region settings in the target location to ensure
> > my image does not get truncated. I will check this out again and
> > get back to you.
> > Charles Beaudry
> > > -----Original Message-----
> > > From: ulf at mail.zmt.uni-bremen.de [mailto:ulf at mail.zmt.uni-bremen.de]
> > > Sent: Wednesday, December 05, 2001 10:33 AM
> > > To: GRASSLIST at baylor.edu
> > > Subject: [GRASSLIST:2735] Re: i.rectify and image resolution
> > > I copied the new datum/ellipse files over the original ones in my
> > > grass5/etc directory. I then deleted and re-created the target
> > > location/mapset with the resolution values, ellipsoid and map datum
> > > you suggested. Anyway, I am still not able to specify a higher
> > > resolution than 0.01 in i.rectify if I choose the option "2. Determine
> > > the smallest region which covers the image". The other option ("1. Use
> > > the current region in the target location") works apparently well.
> > > Many thanks for your advice + help!
> > > Regards, Ulf
> Ulf Mehlig <ulf.mehlig at zmt.uni-bremen.de>
> Center for Tropical Marine Ecology/ZMT, Bremen, Germany
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
