[GRASSLIST:2072] r.in.gdal
ziyadin
cakirz at itu.edu.tr
Thu Jul 5 10:20:19 EDT 2001
Dear all,
-o option in "r.in.gdal" utility does not seem to work.
when i give the command
r.in.gdal input=tmp.tmp.gif output=post -o
grass says
WARNING: G_set_window(): Illegal latitude for North
if I give -e option to extend location extents, it says
cellhd.proj = 0 (unreferenced)
You can use the -o flag to r.in.gdal to override this check.
It gives the same error mesages for all the format that gdal supports.
I installed the precompiled gdal libraries.
Do you think there is something wrong with the the program itself?
I appreciate any hint
Thanks,
Ziya
