[GRASSLIST:2100] Re: digitizer config
Eric G. Miller
egm2 at jps.net
Thu Jul 12 03:28:43 EDT 2001
On Thu, Jul 12, 2001 at 08:54:11AM +0200, georges..schwob wrote:
> Hi Grassers,
> About v.digit the manual says :"GRASS is using device independent code
> written originally by John Dabritz formerly of the Forest Service,
> which uses ascii description files to define how to communicate with
> the digitizer. The result is that we should be able to support just
> about any digitizer out there now with a minimum of work. Refer to the
> "digitizer definition manual" for information on the format of these
> files. Can somebody say me where find that "digitizer definition
> manual". Many thanks in advance.
It's been incorporated into the GRASS5 programming manual.
Eric G. Miller <egm2 at jps.net>
