[GRASSLIST:1947] Re: GRASS 5 environment variables online
Eric G. Miller
egm2 at jps.net
Mon Jun 11 20:46:19 EDT 2001
On Mon, Jun 11, 2001 at 09:00:18PM +0300, ziyadin wrote:
> Hi,
> Where are these variables are defined; in .chsrc or .grass5 or
> .tcltkgrass? Apart from paths, I do not know what values are set to
> what variable or in what file. Could somebody tell give me her/his
> source files (.??) so that I can have an example. Regards, Ziya
$HOME/.grassrc5
Use: g.gisenv set=VARIABLE=VALUE
It looks goofy with two equals signs, but g.gisenv does dual duty for
getting and setting GRASS environment variables. If you just specify a
variable name, it defaults to "get" mode.
GRASS ~> g.gisenv GRASS_GUI
text
Eric G. Miller <egm2 at jps.net>
