[GRASSLIST:2038] RE: GRASS on FreeBSD
    Andrew MacIntyre
    Andrew.MacIntyre at aba.gov.au
    Thu Jun 28 20:27:11 EDT 2001
I'm certain that GRASS 5 has been ported to FreeBSD (though I'm not
sure which actual release).  You should be able to find it in the
FreeBSD ports collection - go to http://www.freebsd.org/ and follow
the "Ported software" link.
You may also (haven't checked) find a binary package that can be
installed with the pkg_add command.
Andrew MacIntyre                  \ E-mail: andrew.macintyre at aba.gov.au
Planning & Licensing Branch        \ Tel:   +61 2 6256 2812
Australian Broadcasting Authority   \ Fax:  +61 2 6253 3277
-> "These thoughts are mine alone!" <----------------------------------
> -----Original Message-----
> From: Dela Lovecraft [mailto:dela at ukonline.co.uk]
> Sent: Friday, 29 June 2001 9:08
> To: grasslist at baylor.edu
> Subject: [GRASSLIST:2037] GRASS on FreeBSD
> Dear All,
> I am looking to get GRASS running on FreeBSD  4.3, but I am a
> bit confused as
> to how to do this.
> I have had a go using the Linux binaries (I have them at
> hand), but they
> don't work. So, I need to compile from source (which I
> thought I might need
> to anyway). The version listed in the ports collection is
> Grass5.0beta8, but
> this is a bit of a problem, since the links to this version are not
> available. I would actually prefer to be running Grass 4.3 at
> the moment as
> well, so...
> ...is it possible to get Grass 4.3 running on FreeBSD as the
> sources are (I
> have to download it, using a slow connection, so haven't
> checked), and how do
> I go about compiling binaries for the newer v5.x Grass ?
> Any help on this would be most appreciated.
> Dela Lovecraft
