[GRASSLIST:2040] RE: GRASS on FreeBSD
Andrew MacIntyre
Andrew.MacIntyre at aba.gov.au
Thu Jun 28 23:51:53 EDT 2001
Well, I just checked the Ports Collection, which lists "grass-5.0b8".
(see http://www.freebsd.org/ports/databases.html)
It appears that binary package building is not enabled for the port.
NOTE: FreeBSD builds many of the ported packages on a build cluster,
with the aim of distributing them on their release CDs, but not all
ports are built into packages, for a variety of reasons.
Andrew MacIntyre \ E-mail: andrew.macintyre at aba.gov.au
Planning & Licensing Branch \ Tel: +61 2 6256 2812
Australian Broadcasting Authority \ Fax: +61 2 6253 3277
-> "These thoughts are mine alone!" <----------------------------------
> -----Original Message-----
> From: Eric G. Miller [mailto:egm2 at jps.net]
> Sent: Friday, 29 June 2001 11:15
> To: grasslist at baylor.edu
> Subject: [GRASSLIST:2039] RE: GRASS on FreeBSD
> > You may also (haven't checked) find a binary package that can be
> > installed with the pkg_add command.
> Not that I'm aware of. Mostly tarballs are distributed (and RPM's
> occasionally).
