[GRASSLIST:2041] RE: GRASS on FreeBSD
    Markus Neteler
    neteler at geog.uni-hannover.de
    Fri Jun 29 05:52:46 EDT 2001
On Fri, Jun 29, 2001 at 01:51:53PM +1000, Andrew MacIntyre wrote:
> Well, I just checked the Ports Collection, which lists "grass-5.0b8".
> (see http://www.freebsd.org/ports/databases.html)
again, please be aware that beta8 is pretty outdated.
We highly recommend to use 5.0.0pre1.
Kind regards
 Markus Neteler
> > -----Original Message-----
> > From: Eric G. Miller [mailto:egm2 at jps.net]
> > Sent: Friday, 29 June 2001 11:15
> > To: grasslist at baylor.edu
> > Subject: [GRASSLIST:2039] RE: GRASS on FreeBSD
> > > You may also (haven't checked) find a binary package that can be
> > > installed with the pkg_add command.
> > Not that I'm aware of.  Mostly tarballs are distributed (and RPM's
> > occasionally).
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
