[GRASSLIST:1565] problems with using d.rast.pg
an lu anlu999 at yahoo.com
Wed Mar 7 17:18:12 EST 2001
in grass5.0, i try to use d.rast.pg to generate and
display a reclass map.
first, i used :
   d.rast.pg key=sect_id tab=rd_tb col=speed
where={rd_tb.speed>60.0} input=rd_map out=new_map
--which all the parameters follow the specification of
the manual( except the where clause, which is not
specified by the manual)
the error info. i got is:
    can not indentify ">", you will have to retype
this query using an explicit cast.
but i can do such query in psql directly.
then i try to use:
  d.rast.pg -s sql=f input=rd_map output=new_map
 with f:
  retrieve unique (color_map002.sect_id,
color_map003.sect_id)
where color_map003.color="green"
getting the error info. : parse error at or near
"retieve".
could anyone tell me how to fix it?
thanks in advance.
--lu
__________________________________________________
Do You Yahoo!?
Get email at your own domain with Yahoo! Mail.
http://personal.mail.yahoo.com/
