[GRASSLIST:2659] Re: naive CVS question
Markus Neteler
neteler at itc.it
Wed Nov 14 04:16:49 EST 2001
On Tue, Nov 13, 2001 at 06:19:15PM -0500, Kevin Slover wrote:
> Erin,
> I just ran into this earlier today, but thankfully have a T1 connection
> to experiment with. You are able to download individual files from the
> CVS link. It might take a bit to find, but each raster library is a
> directory, and you need to of course download just the files from the
> directory...nothing more....
> Erin ODoherty/RMRS/USDAFS wrote:
> > Recently, I was also trying to download Bill Baker's r.le suite for
> > compilation in GRASS5.0 and Linux. I knew that I had to look at the CVS,
> > but it's not clear to me how it works. Do I have to download the whole
> > GRASS5.0 snapshot? I was hesitant to explore deeper because I didn't want
> > to start a long download via modem before I knew what I was getting myself
> > into. Thanks,
> > Erin O'Doherty
a warning:
The Web/CVS interface does NOT show the latest code but the oldish
experimental tree. I strongly advise to use it (and I recommend to
either remove the link or update it).
The two ways to get the latest code from CVS is
- get the CVS snapshot package (you can run cvs up -dP within to update
in future)
- use
cvs -z3 checkout -r releasebranch_11_april_2001_5_0_0 grass
Then you will get all the latest improvements.
Best regards
Markus Neteler
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591) http://mpa.itc.it
