[GRASSLIST:2709] i.rectify and image resolution
ulf at mail.zmt.uni-bremen.de
Thu Nov 29 08:42:48 EST 2001
Hello Grass experts,
I hope you can help me with the following. I'm using grass 5.0.0pre2
on ix86 Linux 2.4. I have an x,y-location with a satellite (I think
Landsat-) image I received from a colleague. The region is:
CURRENT REGION: N=1600 S=0 RES=1 ROWS=1600
E=1600 W=0 RES=1 COLS=1600
PROJECTION: 0 (x,y)
ZONE: 0
Now, I want to rectify the image. I created a target location in
lat/long-coordinate system with the highest resolution I could set,
and the "sam69" spheroid (my image is from equatorial Brazil -- is
this the right choice?).
CURRENT REGION: N= 0:43:48S S=1:12:36S RES=0:00:00.000036 ROWS=48000000
E=46:55:48E W= 46:27E RES=0:00:00.000036 COLS=48000000
PROJECTION: 3 (Latitude-Longitude)
ZONE: 0
DATUM: ** unknown (default WGS84) **
ELLIPSOID: sam69
Then I made an image group, set the target location, and marked points
via i.points (I have tried a set of 8-12 GPS positions of points
+-well recognizable in the image).
Afterwards, I called i.rectify. I specified "choose smallest region
that covers the image" but I was not able to set a higher resolution
than 0.01. The resulting image in the targe location has consequently
only e very rough raster:
CURRENT REGION: N= 0:43:48S S=1:12:36S RES=0:00:36 ROWS=48
E=46:55:48E W= 46:27E RES=0:00:36 COLS=48
ZONE: 0
ELLIPSOID: sam69
I have no idea how to increase the resolution -- can you help me?
Many thanks, Ulf
Ulf Mehlig <ulf.mehlig at zmt.uni-bremen.de>
Center for Tropical Marine Ecology/ZMT, Bremen, Germany
