[GRASSLIST:2710] RE: i.rectify and image resolution
Beaudry Charles (NORANDA)
BeaudryC at normin.com
Thu Nov 29 09:21:37 EST 2001
Ulf Mehlig,
> CURRENT REGION: N=1600 S=0 RES=1 ROWS=1600
> E=1600 W=0 RES=1 COLS=1600
> PROJECTION: 0 (x,y)
> ZONE: 0
I don't know how you are importing the image but if it is in some non-grid
format the above is OK if your image has 1600 pixcels wide and 1600 pixels
high or less. If the image is bigger you will get truncation.
> Now, I want to rectify the image. I created a target location in
> lat/long-coordinate system with the highest resolution I could set,
> and the "sam69" spheroid (my image is from equatorial Brazil -- is
> this the right choice?).
> CURRENT REGION: N= 0:43:48S S=1:12:36S RES=0:00:00.000036
> ROWS=48000000
> E=46:55:48E W= 46:27E RES=0:00:00.000036
> COLS=48000000
> PROJECTION: 3 (Latitude-Longitude)
> ZONE: 0
> DATUM: ** unknown (default WGS84) **
> ELLIPSOID: sam69
TM7 images are 30 m in resolution which, in degrees is about 1 sec (RES =
0:00:00.972) or in decimal circa 0.00027 degrees. The resolution of your
location appears small compared to the resolution of the image.
> Then I made an image group, set the target location, and marked points
> via i.points (I have tried a set of 8-12 GPS positions of points
> +-well recognizable in the image).
> Afterwards, I called i.rectify. I specified "choose smallest region
> that covers the image" but I was not able to set a higher resolution
> than 0.01. The resulting image in the targe location has consequently
> only e very rough raster:
> CURRENT REGION: N= 0:43:48S S=1:12:36S RES=0:00:36 ROWS=48
> E=46:55:48E W= 46:27E RES=0:00:36 COLS=48
> ZONE: 0
> ELLIPSOID: sam69
I have had problems with the SAM69 datum. There appears to be a confusion
in the ellipsoid and datum files. I fixed it but don't have it with me. I
will get it to Markus tonight for uploading to CVS and send a copy directly
to you.
I would set up the right projection and set the resolution of my destination
location to 0:00:0.972 or 0.00027 in decimal before trying to run i.rectify.
Charles Beaudry
This message has been scanned by the AT&T Global Network Services Virus Detect Service. Ce message a ?t? scrut? par le service Virus Detect des Services de r?seaux mondial AT&T.
