[GRASSLIST:2711] nviz help
Kevin Slover
kjslover at nhc.noaa.gov
Thu Nov 29 11:27:47 EST 2001
I am not sure if this is a bug or not in nviz, and am not sure who to
get in touch with to see if I am doing something wrong...but...
I am trying display 2 rasters and a vector...one raster has actual data
with elevations in it, and the other raster, I have set to a constant
value (1). I am wanting to display the vector strictly on the constant
valued raster...I have changed the "display on surface(s)" parameter to
the constant value raster only...however, each time that I hit the draw
button, it resets the display on surface to all surfaces....
I can use the draw current button, but I have to do this in a certain
sequence...or it does the same...anyone hints/tricks/ideas out there??
LTJG Kevin Slover,NOAA GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/National Hurricane Center
11691 SW 17th Street Miami FL 33165
Work: (305) 229-4456 Fax : (305) 553-1264
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20011129/d7a89dd2/attachment.html
