[GRASSLIST:2380] Re: problems with nviz and the tcl/tk 8.3 libraries
Kevin Slover
kjslover at nhc.noaa.gov
Tue Sep 4 08:27:57 EDT 2001
Ivan,
I had the same problem a little while ago when I had reinstalled the latest
version of GRASS5. First, when searching for my libtk8.3.so.1 libraries, I
never had them, I only had the libtk8.3.so library. Reading the archived
GRASSLIST, I discovered that this was the proper library (libtk8.3.so) and
simply soft linked the two. It worked for me, and I have no crashes as a
result... being new to the LINUX world and all, I was not sure in which
directory it was looking, so I made sure that it was linked in every instance,
such that I had it in /usr/local/lib ; /usr/local and /lib ...this might be an
overkill of the situation, but it worked for me..
hope this helps, and if any problems, let me know...I am running RH7.1 and have
it working wonderfully at this point in time...
Ivan Kautter wrote:
> Hello fellow listserv members,
> Thanks for everyone's help regarding install the ncurses libraries but now a
> new problem has cropped up. I tried to run nviz and I received this error
> message:
> usr/local/grass5/etc/nviz2.2/NVWISH2.2: error in loading shared libraries:
> libtk8.3.so.1: cannot open shared object file: No such file or
> directory................
> So after indeed identifying that I needed to update my tcl/tk libraries,
> with some tribulation I did so and attempted to make sure that the newly
> installed files are within my path. Upon typing in nviz after all this, I
> still get the same error message. Did the redhat linux precompiled binaries
> not include the most up to date tcl/tk libraries so that nviz would work?
> If so, then why not? Can anyone tell me what I might have done wrong?
> Indeed the file I have is not named libtk8.3.so.1. It is libtk8.3.so.
> Should that make a difference?
> Again I am not very linux savvy so I might have easily done something wrong,
> like failed to configure tcl/tk or wish after installation if that is
> necessary in this case. Any suggestions? Thanks a bunch.
> Ivan Kautter
> Department of Environmental Science and Policy
> UC Davis
> _________________________________________________________________
> Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp
Kevin Slover, Meteorologist/Oceanographer
Tropical Prediction Center/National Hurricane Center
11691 SW 17th Street Miami FL 33165
Work: (305) 229-4456 Fax : (305) 553-1264
e-mail: kjslover at nhc.noaa.gov kevin.slover at noaa.gov
Web address: http://www.nhc.noaa.gov
