[GRASSLIST:2418] RE: Problems running grass in XWindows in cygwin on NT
ted byers
ted.byers at sympatico.ca
Mon Sep 10 15:49:02 EDT 2001
Thanks Malcolm,
This fixed it, for the most critical part.
> In a Cygwin bash command shell execute:
> tic /usr/X11R6/lib/X11/etc/xterm.termcap //(Xinstall.sh has
> xterm.terminfo)
> This should set up the right xterm definitions so that grass will run
> correctly in XFree86 with TERM=xterm.
But I still get the following error when I exit grass.
"Invalid resource file. removing /home/Bted/.grass5"
Is this resource file something grass creates when it first starts, or do I
need to make one manually (and if so, what goes in it)?
Thanks again,
Ted
