[GRASSLIST:2419] RE: Problems running grass in XWindows in cygwin on NT
ted byers
ted.byers at sympatico.ca
Mon Sep 10 16:04:18 EDT 2001
Thanks Andreas,
First, I would mention that Malcolm's fix for the X Windows installation
fixed the error.
> In a Cygwin bash command shell execute:
> tic /usr/X11R6/lib/X11/etc/xterm.termcap //(Xinstall.sh has
> xterm.terminfo)
> This should set up the right xterm definitions so that grass will run
> correctly in XFree86 with TERM=xterm.
Your batch file also mostly worked. I get the same error when I shut down
grass.
"Invalid resource file. removing /home/Bted/.grass5"
Is this resource file something grass creates when it first starts, or do I
need to make one manually (and if so, what goes in it)?
More significantly for your batch file, there is a slight error in it.
I had made the following change, to fit my setup:
REM ----- Path to your CYGWIN ROOT
REM set CYGWIN=\cygwin
set CYGWIN=\Gnu
REM
As well as the following change:
REM ----- Adapted for XFree86
REM set BIN=.;\cygwin\bin
REM set LIB=\cygwin\usr\X11R6\bin;\cygwin\usr\X11R6\lib
set BIN=.;\GNU\bin
set LIB=\GNU\usr\X11R6\bin;\GNU\usr\X11R6\lib
Then, What I see is an initial message from cmd.exe is that a path is not
found, and then grass appears to start normally.
Then I looked in your batch file and saw the following:
REM
REM ------------------------------------------------------------------------
REM ----- nothing to change below!
REM
REM ----- This is your local DISPLAY
set DISPLAY=127.0.0.1:0.0
REM
REM ----- Cleanup after last run.
REM
if not exist \cygwin\tmp\.X11-unix\X0 goto CLEANUP-FINISH
attrib -s \cygwin\tmp\.X11-unix\X0
del \cygwin\tmp\.X11-unix\X0
:CLEANUP-FINISH
rmdir \cygwin\tmp\.X11-unix
REM
It seems to me that the statement about nothing to change after it is in the
wrong place since I ought to have changed the paths in the cleanup section
of the script to reflect my setup also.
Thanks again,
Ted
