[GRASSLIST:2500] Re: Problems with GRASS5 r.in.ascii
    Markus Neteler
    neteler at itc.it
    Thu Sep 27 03:08:47 EDT 2001
On Thu, Sep 27, 2001 at 01:53:27PM +1000, Terry Duell wrote:
> Hullo All,
> I have recently built grass5.0.0pre2 in order to over some difficulties with
> v4.3, and seem to have run into a nasty little problem.
> I have been generating raster ascii data and thought I would take advantage
> of the null value feature of GRASS5, so altered the way my data was being
> generated to include 'null: -99' in the header of the raster ascii files.
> When I try to run r.in.ascii I get a segmentation fault and a core dump.
> Importing v4.x ascii raster format is OK.
> Is this a known problem, or is more likely to be something I have done?
> Cheers,
> Regards,
Hi Terry,
please post the header of your ASCII file. Maybe we get an idea then.
Usually r.in.ascii runs fine.
Best regards
 Markus Neteler
