[GRASSLIST:4213] d.what.v.pg
orkun temiz at deprem.gov.tr
Mon Aug 5 03:56:04 EDT 2002
 A problem raises over d.what.v.pg
GRASS:~ > d.mon start=x0
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
GRASS:~ > d.vect map=f28mr color=green
GRASS:~ >  g.select.pg database=dbbk1
GRASS:~ > d.what.v.pg map=f28mr tab=koy col=no color=green
No socket to connect to for monitor <x0>.
what is the reason of the problem concerning the last command ?
kind regards
Ahmet Temiz
Geological Engineer
General Directorate
of Disaster Affairs
TURKEY
______________________________________
Scanned and protected by Inflex
http://pldaniels.com/inflex
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
