[GRASSLIST:5207] Re: g.region help
Malte Martin
malte at geog.fu-berlin.de
Tue Dec 10 13:29:34 EST 2002
I'm not quite shure (I have never done this before), but when you're
using r.in.gdal you can extend the region settings. You should take a
look at the r.in.gdal manpage. Hope This will help.
Malte
Kevin Slover wrote:
>I am having a bit of a dilemma, and I am sure there is any easy way to
>resolve it...I hope...
>I am currently importing what will soon be 4000+ arcview grid files
>using the r.in.arc command. However, the raster produced encompases the
>entire pre-set region. Is it possible to set the region via the input
>file? I know there is a g.region rast=<filename>, but the raster must
>already be present...Any ideas?
