[GRASSLIST:5209] Re: 3D
H. Bowman
ihatejunkyabastards at yahoo.com
Tue Dec 10 18:08:30 EST 2002
> > - can I add 3D object like a sphere?
Yes. Spheres and 3D diamonds..
You can draw a sphere by displaying in NVIZ a sites file with the sphere's center as each point. Create a new constant surface (Panel->Surfaces), set transparency to full, and raise or lower the surface to your desired elevation with the Position button. Then Panel->Sites, load the sites file, and tell it to use the sphere, set the size, color etc.
g'luck
