[GRASSLIST:3201] Re: s.ou.ascii terminates in 5.0.pre2
Al Green ihatejunkyabastards at yahoo.com
Sun Feb 24 03:14:47 EST 2002
> If I want to convert a raster map to an ascii table with X Y Z,
> s.out.ascii is suddebly killed. I use the following command:
> s.out.ascii -d sites=landuse.dat > ~/landuse.txt
> But suddenly the swap is filled up and the program terminates.
> Any suggestions or ideas how to solve this problem?
I had the same problem recently.
Solution: install Grass on the guy across the halls brand new machine with
3 times the memory and 4 times the processing power that my machine has.
Made it all the way though without getting killed.
Well, it worked for me.
Or a better way, I figured out after that mess, was to just copy out the
file from the site_lists directory. It's already in ascii format. Search &
replace the deliminators with a text editor strong enough to deal with a
file that size and you're done.
g'luck.
__________________________________________________
Do You Yahoo!?
Yahoo! Sports - Coverage of the 2002 Olympic Games
http://sports.yahoo.com
