[GRASSLIST:4105] Re: r.in.gdal question
Kevin Slover kevin.slover at noaa.gov
Fri Jul 19 11:20:56 EDT 2002
Is there a way to check if you are installing with the "with-gdal" option??
I have ran configure with pre5 as follows:
./configure --without-postgres --without-fftw --with-gdal
Looks correct??
Glynn Clements wrote:
> Kevin Slover wrote:
> > Alrighty, got it working, somewhat.  Realized why gdal wasn't installed,
> > and simply recompiled with the --with/--without flags as needed.  And of
> > course, after all that, the format that I need to use (.kap) is not
> > supported, or at least the version that I have..interesting...anyhow,
> > thanks for all the help out there...
> Note that the treatment of the --with-gdal flag is different to most
> of the other --with-* flags.
> If you specify --with-gdal, r.in.gdal includes gdal.h, and links
> directly against libgdal, as is the case for other libraries.
> Without the --with-gdal switch, r.in.gdal includes gdalbridge.h (which
> is part of the r.in.gdal source code), and doesn't link against
> libgdal; instead, it loads libgdal at run-time using dlopen().
> Glynn Clements <glynn.clements at virgin.net>
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
