[GRASSLIST:3878] Re: Projection and m.in.e00
Kirk Schmidt
kirkschmidt at auracom.com
Fri Jun 14 09:49:27 EDT 2002
I am not familiar with the m.in.e00 however, your projection is
incorrect: The coordinates are not lat/long.
The original data may have been in lat/long, but appears to have been
reprojected to another projection/datum. I don't recognize
the coordinate system as you reported them.
How about converting the data to a shapefile outside of grass and using
v.in.shape .
Thetas all I can contribute
Cheers
Kirk Schmidt
Ben Logan wrote:
>Hi, all.
>Thanks to those who replied to my last question (about v.in.shape).
>Now I've come up with one about m.in.e00.
>I converted some ARC/INFO Coverages to e00 format with avcexport from
>the avce00 suite. That part went okay. If I try to import the e00
>into my current mapset under GRASS with m.in.e00, I get an error about
>an invalid value for the north bound. I read about the projection
>problems with m.in.e00 in the manpage, so I specified a new mapset
>when I ran the command again. There were no errors that way, but
>something's still out of whack. Here's the projection info from
>v.info on the map that I imported (which is of Carroll County, VA):
> Projection: Latitude-Longitude (zone 0)
> N: 104035 S: 62514
> E: -85283 W: -137642
>I know that the original projection for the coverage was lat/lon, so
>that part should be right, but those values don't look good to me. :)
>I can tell it, too, when I use d.vect to display the newly created
>map--it is stretched vertically.
>Is there anything I can do about all this? BTW, I tried using
>m.in.e00 with verbose=1 to see what the region for the map should be,
>but it didn't appear to tell me:
>GRASS:~/grass5.0 > m.in.e00 input=carroll_roads.e00 mapset=junk
>verbose=1
>"carroll_roads.e00" successfully opened
>ARC 3
>Arc coverage : 1921 arcs (22488 points)
>CNT 3
>LAB 3
>Label table : 405 entries
>PAL 3
>PAL : 405 polygons (3849 arcs referenced)
>TOL 3
>TX6 3
>SIN 3
>PRJ 3
>IFO 3
>ROADS.TIC XX 3 20 4
>ROADS.BND XX 4 32 1
>INFO table .BND
>Creating region
>ROADS.PAT XX 4 24 405
>ROADS.TATSMALL XX 11 74 641
>ROADS.AAT XX 24 150 1921
>Writing cats file "roads.county-code"
>Writing cats file "roads.route-name"
>Writing cats file "roads.route"
>Writing cats file "roads.alt-routes"
>Writing cats file "roads.road-type"
>Writing cats file "roads.surface-type"
>Writing cats file "roads.bridge-code"
>Writing cats file "roads.symbol"
>Writing cats file "roads.chgby"
>Writing cats file "roads.chgdate"
>Writing cats file "roads.level"
>Writing cats file "roads.color"
>Writing cats file "roads.style"
>Writing cats file "roads.weight"
>Writing cats file "roads.district"
>Writing cats file "roads.sequence"
>Writing cats file "roads.sub_code"
>ROADS.NAT XX 10 76 1520
>ROADS.TATMAIN XX 11 74 1410
>getinfo returns Cover_type = 3
>EOS
>Creating dig_att(L) file "roads"
>Updating dig_att(A) file "roads"
>Import of roads complete
>Thanks,
>Ben
