[GRASSLIST:3680] Error in g.setproj for State Plane projection
Robert Stein
rjstein at iupui.edu
Fri May 17 10:48:38 EDT 2002
Hello,
I am having some problems defining a state plane projection in grass5.0 using g.setproj here are the results that I'm seeing
I give the following parameters to g.setproj
Projection name: stp
Ellipsoid name: clark66
Datum: nad27
FIPS State Code: 18 (IN)
FIPS County Code: 97 (Marion)
When I get to the end of specifying these parameters... I get...
ERROR: This should not happen see your system admin
Any ideas? Help would be greatly appreciated... if this can't be solved then suggestions on converting State Plane to something else that grass can read would also be welcome :)
Thanks
Rob
Robert Stein
Senior Technical Lead
Pervasive Technology Labs
Indiana University, Indianapolis
(317) 278-8154 / rjstein at iupui.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20020517/c230eae4/attachment.html
