[GRASSLIST:3681] Re: Error in g.setproj for State Plane projection
Eric G. Miller
egm2 at jps.net
Fri May 17 11:57:53 EDT 2002
On Fri, May 17, 2002 at 08:48:38AM -0600, Robert Stein wrote:
> Hello,
> I am having some problems defining a state plane projection in
> grass5.0 using g.setproj here are the results that I'm seeing I
> give the following parameters to g.setproj
> Projection name: stp
> Ellipsoid name: clark66
> Datum: nad27
> FIPS State Code: 18 (IN)
> FIPS County Code: 97 (Marion)
> When I get to the end of specifying these parameters... I get...
> ERROR: This should not happen see your system admin
> Any ideas? Help would be greatly appreciated... if this can't be
> solved then suggestions on converting State Plane to something else
> that grass can read would also be welcome :)
Seems to be a problem in reading the state plane parameters. Did
something corrupt grass5/etc/state27? If you know the parameters for
the zone in question, you can just specify them directly (though, GRASS
won't know it's state plane then, but that shouldn't matter much).
Eric G. Miller <egm2 at jps.net>
