[GRASSLIST:3743] Re: d.zoom question
Kevin Slover kjslover at nhc.noaa.gov
Fri May 24 11:18:16 EDT 2002
I just downloaded and installed the pre4 version from the most recent CVS.
For the first time when installing grass, I get an error message while doing
make install.  It is as follows:
test -d /usr/local/grass/dist.i686-pc-linux-gnu/locale && /bin/sh -c "cd
/usr/local/grass/dist.i686-pc-linux-gnu ; tar cBf - locale | (cd
/usr/local/grass5 ; tar xBf - ) 2>/dev/null ; true"
make[1]: *** [real-install] Error 1
make[1]: Leaving directory `/usr/local/grass'
make: *** [install] Error 2
It appeared to install some of the functions.  I tried using tcltkgrass, and
it worked fine.  However, I experiences the same problem as H. Bowman.  I
brought up a vector file, and used d.zoom.  It allowed me to zoom, however,
came up with a blank screen.  I quit d.zoom, and tried to restart.  This
time, it tells me that I need a raster file.   Any thoughts??
I have not tried any of the other functions with pre4 after the failed
install.  I guess I will revert back to my original installation of pre3,
since I am using GRASS on a daily basis.
LTJG Kevin Slover, NOAA
GIS Specialist/Meteorologist/Oceanographer
Tropical Prediction Center/Technical Support Branch
11691 SW 17th Street Miami FL 33165
(W) 305-229-4456  (F) 305-553-1264
