[GRASSLIST:4795] Re: r.in.tiff generates empty map
Glynn Clements
glynn.clements at virgin.net
Tue Oct 22 02:54:08 EDT 2002
dave wrote:
> I am trying to import a tiff image (rbg, geotiff) and r.in.tiff always
> runs without error, but generates three null raster map ( print white
> with d.display ). Is the tiff in unsupported format, or is it an bug in
> r.in.tiff?
Probably neither. The usual reason is that the data doesn't lie within
the current region. You can use r.info to determine the boundaries of
the imported map, and "g.region -p" to determine the current region.
You can change the current region to match a raster map's boundaries
with "g.region rast=...", or change the boundaries of a map with
r.region or r.support.
Glynn Clements <glynn.clements at virgin.net>
