[GRASSLIST:4827] Re: Alternate ODBCs in SuSE 8.1
Otto Dassau
otto.dassau at GMX.de
Fri Oct 25 06:18:14 EDT 2002
Hi John,
I hope you don't give up
I work with Suse 8.1 and a current CVS GRASS version. I installed
the unixODBC packages where libodbc is included.
There were no problems or conflicts ... and I did not need to
define special ODBC options or solve conflicts or use
compiling options to get ODBC support in GRASS.
The same you described for your 8.0 version -> no difference
Maybe your libodbc version is from an older (8.0) installation? You
should remove and install the packages again.
Otto
John Dougherty schrieb:
> On Wednesday 23 October 2002 00:45, you wrote:
> > John Dougherty wrote:
> > > I just recompiled GRASS 5.0 for SuSE 8.1. Most of the process proved
> > > reasonably straightforward. However, the ODB library(ies) proved a
> > > little problematic. There are obdc libs installed with main
> > > installation, however GRASS seems to be in need of the unixODBC, or at
> > > least that seemed to be what solved the problem. SuSE however, alerts
> > > repeatedly that the unixODBC and the libodbc already installed can cause
> > > conflicts and may destablize the system. Are there any recommendations
> > > about handling this from the GRASS team?
> > Install UnixODBC where other programs won't find it, i.e. somewhere
> > other than /usr/{include,lib} or /usr/local/{include,lib}; e.g.
> > /opt/UnixODBC/{include,lib}.
> > When configuring GRASS, use --with-odbc-includes= and
> > --with-odbc-libs= to tell the configure script where to find it.
> > Once GRASS has been installed, add the library directory (e.g.
> > /opt/UnixODBC/lib) to the LD_LIBRARY_PATH setting in
> > $GISBASE/etc/Init.sh.
> > However, this typically won't work if you use tcltkgrass and xterm is
> > setuid root, as setuid programs discard the value of LD_LIBRARY_PATH.
> > In that case, build a static version of the UnixODBC library instead
> > of a shared library (use --enable-static and --disable-shared).
> Glenn,
> Thanks for the response. I AM using tcltkgrass (therebye hangs yet another
> tail). Since my system is stand alone and things are working, I have filed
> your message and I will watch things develope - or not. The SuSE YAST2
> installer did not offer an option to relocate the package so I am not going
> to meddle further yet, 8.0 worked fine as installed without any announcements
> of potential conflicts or --with-odbc-inludes.
> John
