[GRASSLIST:4463] [Fwd: Re: how to generate high resolution image?]
William W. Hargrove
hnw at fire.esd.ornl.gov
Wed Sep 11 14:58:09 EDT 2002
It can be helpful to increase the resolution in whatever ps.map device file
you are using. Otherwise, I think it throws away resolution that can't be
seen on the "paper page".
Makes the files a lot bigger, of course.
Miserable powerpoint may shred your map anyway, though ... :-0
Bill H.
Glynn Clements wrote:
> Xueming Wu wrote:
> > I want to transform my composing map which include
> > raster, verctors, site and legend into a image so that
> > the image can be inserted into a powerpoint slice.
> > I used the following method:
> > ps.map --> pstopnm --> ppm2tiff or pnmtojpeg or ppmtogif.
> > But none of the images can meet my requirement for resolution.
> > Any suggestion or idea? Thank you.
> If resolution is the issue, don't convert the vector maps to rasters.
> Instead, use the PostScript file directly; if PowerPoint can't handle
> PostScript, then convert it to a *vector* format which PowerPoint can
> handle (Maybe it supports WMF?).
> If you can't find any way of importing the data into PowerPoint
> without rasterising the vector layers, then use a higher resolution.
> Calling "gs" directly (rather than using pstopnm) will allow you to
> exercise more control.
> Glynn Clements <glynn.clements at virgin.net>
William W. Hargrove hnw at fire.esd.ornl.gov
Environmental Sciences Division (865) 241-2748
Oak Ridge National Laboratory (865) 574-4665 (fax)
P.O. Box 2008, M.S. 6407 http://research.esd.ornl.gov/~hnw
Oak Ridge, TN 37830-6407 FedEx/UPS, use "Bethel Valley Rd."
