[GRASSLIST:5974] Re: Postgress and GRASS CD
cheg01 at attbi.com
cheg01 at attbi.com
Tue Apr 8 10:38:28 EDT 2003
Are you aware that you have to use the "-i" option on postmaster to use it
with Grass?
>From "man postmaster""
-i This enables TCP/IP or Internet domain socket com-
munication. Without this option, only local Unix
domain socket communication is possible.
Despite what the man says, I have to use this option on the local host or
it will not connect.
----- Original Message -----
To: "Schuyler Fishman" <schuylerfish at earthlink.net>
Cc: <grassLIST at baylor.edu>
Sent: Tuesday, April 08, 2003 5:07 AM
Subject: [GRASSLIST:5972] Re: Postgress and GRASS CD
> Hi,
> I've been getting the exact same message using the OpenOSX CD.
> PostgreSQL _is_ installed by the CD and there are some notes on the CD
> about logging in and changing the postgres user password after
> installation.
> I've also done some tinkering trying to start up new databases. I think
> I've managed to get postmaster up and running from the postgres account
> but i can't seem to connect to it - this is where I get your error
> message.
> David Orme.
> On Monday, April 7, 2003, at 05:27 pm, Schuyler Fishman wrote:
> > I am having difficulty using postgres and grass gis. Is it installed
> > with the cd?
> > I get the following error message
> > The following databases are in the Unix catalogue:
> > Error: select Postgres:could not connect to server: No such file or
> > directory
> > Is the server running locally and accepting
> > connections on Unix domain socket "/tmp/.s.PGSQL.5432"?
> > Schuyler Fishman
> > Schuylerfish at earthlink.net
> > www.mindlikesky.com
