[GRASSLIST:1072] Re: r.in.gdal installation
Martin Wegmann mailinglist.wegmann at gmx.net
Fri Aug 29 12:37:51 EDT 2003
On Thursday 28 August 2003 05:05, Glynn Clements wrote:
> Martin Wegmann wrote:
> > quite a while ago I installed the source code of 5.0.2 but unfortunately
> > without r.in.gdal. Now I want to install this module and followed the
> > instruction on the grass site:
> Note that r.in.gdal isn't optional; "make" will always attempt to
> build it. By default, r.in.gdal will attempt to load the GDAL library
> (libgdal) dynamically; libgdal doesn't have to be present in order to
> compile r.in.gdal.
ok, well then only libgdal is missing, thanks for this info
> So, provided that you are using a platform which provides dlopen()
> (e.g. Linux, Solaris, available as an add-on for MacOSX)
it's Linux
> didn't use --with-gdal (which results in r.in.gdal linking directly to
> libgdal), you should already have r.in.gdal; you just need to install
> libgdal in a suitable location.
how do I install libgdal (as well with gmake5 as you described?) and what is a
suitable location?
as far as I understood your gmake5 instruction, I do have to reinstall the
grass5 source so that the files are partially build/configured before I will
be able to install libgdal, don't I?.
thanks Martin
> > Installing single modules from source:
> > The "configure" process creates two scripts (after "make install"
> > these scripts will be stored in /usr/local/bin/ if not having used
> > configure's option "--with-bindir")
> >    gmake5
> >    gmake5 -i
> >    gmakelinks5 -i
> > Use script "gmake5" to compile single modules locally, run
> > "gmakelinks5" afterwards to set internal links for the new module.
> > The "-i" flag will install them into target directory, so that no
> > further "make install" is required.
> > but I get the following prompt
> > oggi at wz3x64:/usr/local/bin> gmake5
> > /usr/local/bin/gmake5: line 9:
> > /home/oggi/GRASS/GRASS_502/grass5.0.2/src/CMD/generic/gmake.sh: No such
> > file or directory
> > this folder has been deleted during my last clean-up session :-(  would
> > this problem be solved if I download the source again and extract it in
> > the same path? or did grass modify these files during installation?
> In order for gmake5 to work, the GRASS source needs to be installed in
> the directory referenced by the gmake5 script, and it needs to have
> been configured and at least partially built.
> > and when do I tell grass to install r.in.gdal?
> The correct usage of gmake5 is to either specify the pathname to the
> module's directory, relative to the top of the GRASS source tree, e.g.
> 	gmake5 -i src/raster/r.in.gdal
> or to change to the module's directory and run gmake5 without a
> pathname, e.g.
> 	cd /home/oggi/GRASS/GRASS_502/grass5.0.2/src/raster/r.in.gdal
> 	gmake5 -i
