[GRASSLIST:2117] Re: New Location
    Maliheh
    malihehs at yahoo.com
    Wed Dec 31 07:05:28 EST 2003
Thank you Daniel,
I checked it, but my problem didn't solved :(
My another problem is When I use r.in.gdal to import a jpg file, it says:
r.in.gdal input=teh10.jpg output=test
PROJ_INFO file not found for location mtest7
PROJ_UNITS file not found for location mtest7
 100%
CREATING SUPPORT FILES FOR test.red
SETTING GREY COLOR TABLE FOR test.red (8bit, full range)
 100%
CREATING SUPPORT FILES FOR test.green
SETTING GREY COLOR TABLE FOR test.green (8bit, full range)
 100%
CREATING SUPPORT FILES FOR test.blue
SETTING GREY COLOR TABLE FOR test.blue (8bit, full range)
so I have 3 raster map in my location, but I can't see any of them by use of d.rast or d.rgb,
Would you please tell me my wrong?
Daniel Victoria <daniel_victoria at yahoo.com> wrote:
Maliheh,
I'm not an expert here but, if you know the lat/long
of your region, why are you creating a XY region and
not a lat/long?
Maybee that's it, but once again, I'm not an expert...
Cheers
Daniel
--- Maliheh wrote:
> Hello dear GRASS list,
> I want to describe my problem from the beginning for
> you, I wish you can and you want to help me and also
> it can be helpful for others.
> I want to create a new location for my region; I
> dont have any digital map that match my need, I
> have just a paper map and a GPS receiver, with use
> of gpsdrive I noted coordinates of four points on my
> map. Gpsdrive shows the coordinates like this:
> Latitude: 35.73581 Longitude: 51.40387
> And also I know that my region is between 34:52N ,
> 34:21N and 50:10E , 53:10E; and my map scale is
> 1/12000 and the resolution of scanned map is 100dpi.
> Now start the grass5.7 for creation new location:
> a. LOCATION: test________
> (enter list for a list of locations)
> MAPSET: root__________ (or
> mapsets within a location)
> DATABASE: /usr/local/src/GIS/grassdata
> b. LOCATION - doesn't exist
> Would you like to create location ? (y/n) y
> c. To create a new LOCATION, you will need the
> following information:
> 1. The coordinate system for the database
> x, y (for imagery and other unreferenced
> data)
> Latitude-Longitude
> UTM
> Other Projection
> 2. The zone for the UTM database
> and all the necessary parameters for projections
> other than
> Latitude-Longitude, x, y, and UTM
> 3. The coordinates of the area to become the default
> region
> And the grid resolution of this region
> 4. A short, one-line description or title for the
> location
> Do you have all this information for location
> ? (y/n) y
> d. Please specify the coordinate system for
> location
> A x, y
> B Latitude - Longitude
> C UTM
> D Other Projection
> RETURN to cancel
> > A
> x, y coordinate system? (y/n) [y] y
> e. Please enter a one line description for
> location
> > Create a new Location
> Ok? (y/n) [y] y
> f. DEFINE THE DEFAULT REGION
> ====== DEFAULT REGION ====
> | NORTH EDGE: 36
> WEST EDGE |
> | EAST EDGE
> 50 |
> | 53
> | SOUTH EDGE: 34
> PROJECTION: 0 (x, y)
> ZONE: 0
> GRID RESOLUTION
> East-West: 0.03
> North-South: 0.02
> g. projection: 0 (x,y)
> zone: 0
> north: 36
> south: 34
> east: 53
> west: 50
> e-w res: 0.02 (Changed to conform to grid)
> n-s res: 0.03 (Changed to conform to grid)
> total rows: 100
> total cols: 100
> total cells: 10000
> Do you accept this region? (y/n) [n] > y
> LOCATION has been created!
> I know that in some steps specially those with red
> highlight, Ive done something wrong, but I dont
> know
=== message truncated ===
__________________________________
Do you Yahoo!?
Find out what made the Top Yahoo! Searches of 2003
http://search.yahoo.com/top2003
Do you Yahoo!?
Yahoo! Photos - Get your photo on the big screen in Times Square
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20031231/2ce2cf2a/attachment.html
