[GRASSLIST:5563] Re: i.composite problem: gives minmax 1:1, grass5
Glynn Clements
glynn.clements at virgin.net
Sat Feb 15 17:50:50 EST 2003
Philipp Molzer wrote:
> Thanks. Unfortunately, d.rgb gives me an image with quite bizarre
> colors.
Then you probably need to do:
for i in 1 2 3 ; do
( echo 0 black ; echo 255 white ) | r.colors map=294.JPG.$i color=rules
done
r.in.gdal really ought to set a colour table, but it doesn't.
Glynn Clements <glynn.clements at virgin.net>
