[GRASSLIST:5587] Re: GRASS 5.0.1 compilation issues
Glynn Clements
glynn.clements at virgin.net
Mon Feb 17 16:37:51 EST 2003
Wayne Gibson wrote:
> Running d.where also had some troubles. When I issued the command,
> an endless stream of coordinate were displayed until I made the 1st
> mouse click. Then the command worked as it should (1 pair of
> coordinates per mouse click).
I've found the bug. FWIW, it occurs when an uninitialised variable
happens to contain -1.
You can obtain an updated version of the file from:
http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass/src/display/devices/XDRIVER/XDRIVER24/Get_w_pnt.c?rev=1.11&content-type=text/plain
The file in question is:
Glynn Clements <glynn.clements at virgin.net>
