[GRASSLIST:5589] Re: GRASS 5.0.1 compilation issues
Glynn Clements
glynn.clements at virgin.net
Mon Feb 17 19:43:22 EST 2003
Wayne Gibson wrote:
> I've been wrestling with compiling all day and have discovered a couple other
> issues.
> 1) For some reason, when compiling the code in directory "r.tiff", the "jpeg"
> lib is not included on the compile line. I added "-ljpeg" in Gmakefile and it
> appears to compile without errors.
Argh:
LIBTIFF = $(TIFFLIBPATH) $(JPEGLIBPATH) -ltiff $(ZLIB)
The configure script specifically checks for JPEG, and adds
$JPEGLIBPATH $JPEGLIB to the definition of TIFFLIB if it's required.
Of course, that is of absolutely no use if r.tiff/Gmakefile doesn't
actually use $(TIFFLIB).
It should be:
LIBTIFF = $(TIFF_LIBRARY_DIRS) $(TIFFLIB)
Anything else which is required should have been added to TIFFLIB by
configure (it checks for JPEG, zlib and the math library).
> 2) When compiling the code in PNGdriver, there is a reference to
> "sun" and "cos" which I'm sure are in libm.a. Here I also changed
> the Gmakefile and added "-lm" and the code now copiles without
> errors.
That's a known bug; the configure script has already been fixed in
CVS.
> I don't know if these are accidental omissions or platform specific issues.
Accidents.
However, while something which fails on Linux (which seems to account
for ~90% of our user base) will be found quickly, something that only
fails on a less-popular platform will only be found when someone
actually tests on that platform.
> 3) Compiling in src/general/init for "set_data"
> ld: warning: symbol `numcodes' has differing sizes:
> (file /usr/local/lib/libncurses.so value=0xa0; file
> /usr/lib/libtermlib.so value=0x88);
> /usr/local/lib/libncurses.so definition taken
The use of termlib was bogus, and has since been removed.
> This looks like a problem with set_data. Which curses library should
> be used? I find /usr/lib/libcurses and /usr/local/lib/libncurses.
Normally libraries which are in /usr/lib are a safer bet than those in
/usr/local/lib. However, you don't get to pick and choose specific
directories for specific libraries; if /usr/local/lib is searched for
any library, it is searched for all of them.
Am I correct in assuming that zlib is in /usr/local/lib? If so, then
the only way (AFAIK) to avoid getting the libncurses from
/usr/local/lib is to create a private library directory, populated
with symlinks to the required libraries (e.g. zlib), and specify that
instead of /usr/local/lib.
> I still get the error message when starting grass:
> Sorry, I need to know a more specific terminal type than "".
> TERM is set to "xterm" ("echo $TERM" just prior to set_data in Init.sh)
OK, then it's a library problem. Possibly termlib, possibly the wrong
libncurses.
Try setting TERMLIB to empty in the src/CMD/head/head.<arch> file,
then re-compiling.
> 4) In one of the email archives, there was a discussion about using fifos.
> Should sockets be used in most cases?
Yes.
Glynn Clements <glynn.clements at virgin.net>
