[GRASSLIST:5649] r.in.gdal problems, and d.zoom problems.
    Ben Logan
    ben at wblogan.net
    Sun Feb 23 20:19:49 EST 2003
Hello,
I compiled Grass 5.0.1 subsequent to installing gdal-1.1.8.  r.in.gdal
will work to import Geotiff images, but when I try to import USGS SDTS
DEMs (ones which I have successfully imported with previous versions
of GRASS), r.in.gdal segfaults with no message other than
"Segmentation Fault".  I've attached the output from running strace in
case it can help.
The other odd thing is that I can't zoom in on a vector map with
d.zoom.  After zooming, the vectors simply won't show up.  However,
d.zoom works as expected with raster maps.
Am I the only one with these problems, or are they known bugs?
Thanks,
Ben
PS.
I'm going to email the webmaster of the site where I got those old
beta11 sources, and I'll cc (or bcc) the list when I do.
Ben Logan
Google Answers Researcher
answers.google.com
When you're searching for information, Google Answers.
Gravity brings me down.
execve("/usr/local/grass5/bin/r.in.gdal", ["r.in.gdal", "input=9942CATD.DDF", "output=dugspur.elev"], [/* 53 vars */]) = 0
uname({sys="Linux", node="mach1.log.cabin", ...}) = 0
brk(0)                                  = 0x807e74c
open("/etc/ld.so.preload", O_RDONLY)    = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/i586/mmx/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib/i586/mmx", 0xbfffea80) = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/i586/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib/i586", 0xbfffea80) = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/mmx/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib/mmx", 0xbfffea80) = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/libm.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0
open("/etc/ld.so.cache", O_RDONLY)      = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=112439, ...}) = 0
old_mmap(NULL, 112439, PROT_READ, MAP_PRIVATE, 3, 0) = 0x40012000
close(3)                                = 0
open("/lib/libm.so.6", O_RDONLY)        = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\3006\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=166736, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4002e000
old_mmap(NULL, 131584, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4002f000
mprotect(0x4004f000, 512, PROT_NONE)    = 0
old_mmap(0x4004f000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x4004f000
close(3)                                = 0
open("/usr/local/grass5/lib/libz.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libz.so.1", O_RDONLY)    = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\30"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=60805, ...}) = 0
old_mmap(NULL, 55308, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40050000
mprotect(0x4005c000, 6156, PROT_NONE)   = 0
old_mmap(0x4005c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xb000) = 0x4005c000
close(3)                                = 0
open("/usr/local/grass5/lib/libc.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libc.so.6", O_RDONLY)        = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0hU\1\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=1327065, ...}) = 0
old_mmap(NULL, 1171268, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4005e000
mprotect(0x40173000, 36676, PROT_NONE)  = 0
old_mmap(0x40173000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x115000) = 0x40173000
old_mmap(0x40178000, 16196, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40178000
close(3)                                = 0
munmap(0x40012000, 112439)              = 0
brk(0)                                  = 0x807e74c
brk(0x807f74c)                          = 0x807f74c
brk(0x8080000)                          = 0x8080000
umask(022)                              = 022
ioctl(0, SNDCTL_TMR_TIMEBASE, {B38400 opost isig icanon echo ...}) = 0
access("/usr/local/grass5/etc/bin/cmd/r.in.gdal", X_OK) = 0
execve("/usr/local/grass5/etc/bin/cmd/r.in.gdal", ["r.in.gdal", "input=9942CATD.DDF", "output=dugspur.elev"], [/* 53 vars */]) = 0
brk(0)                                  = 0x80abd0c
open("/usr/local/grass5/lib/i586/mmx/libgdal.1.1.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib/i586/mmx", 0xbfffea70) = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/i586/libgdal.1.1.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib/i586", 0xbfffea70) = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/mmx/libgdal.1.1.so", O_RDONLY) = -1 ENOENT (No such file or directory)
stat64("/usr/local/grass5/lib/mmx", 0xbfffea70) = -1 ENOENT (No such file or directory)
open("/usr/local/grass5/lib/libgdal.1.1.so", O_RDONLY) = -1 ENOENT (No such file or directory)
close(3)                                = 0
open("/usr/local/lib/libgdal.1.1.so", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\350,\6"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=2962677, ...}) = 0
old_mmap(NULL, 2713600, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4002f000
mprotect(0x4024e000, 489472, PROT_NONE) = 0
old_mmap(0x4024e000, 405504, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x21e000) = 0x4024e000
old_mmap(0x402b1000, 83968, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x402b1000
close(3)                                = 0
old_mmap(NULL, 131584, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x402c6000
mprotect(0x402e6000, 512, PROT_NONE)    = 0
old_mmap(0x402e6000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x20000) = 0x402e6000
close(3)                                = 0
old_mmap(NULL, 55308, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x402e7000
mprotect(0x402f3000, 6156, PROT_NONE)   = 0
old_mmap(0x402f3000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xb000) = 0x402f3000
close(3)                                = 0
old_mmap(NULL, 1171268, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x402f5000
mprotect(0x4040a000, 36676, PROT_NONE)  = 0
old_mmap(0x4040a000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x115000) = 0x4040a000
old_mmap(0x4040f000, 16196, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4040f000
close(3)                                = 0
open("/usr/local/grass5/lib/libdl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.2", O_RDONLY)       = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\\\27\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=10825, ...}) = 0
old_mmap(NULL, 10888, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40413000
mprotect(0x40415000, 2696, PROT_NONE)   = 0
old_mmap(0x40415000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x40415000
close(3)                                = 0
open("/usr/local/grass5/lib/libpq.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libpq.so.2", O_RDONLY)   = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300=\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=87487, ...}) = 0
old_mmap(NULL, 76664, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40416000
mprotect(0x40428000, 2936, PROT_NONE)   = 0
old_mmap(0x40428000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x11000) = 0x40428000
close(3)                                = 0
open("/usr/local/grass5/lib/libungif.so.4", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libungif.so.4", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\26"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=38261, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40429000
old_mmap(NULL, 30364, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4042a000
mprotect(0x40431000, 1692, PROT_NONE)   = 0
old_mmap(0x40431000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x7000) = 0x40431000
close(3)                                = 0
open("/usr/local/grass5/lib/libstdc++.so.5", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/libstdc++.so.5", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\300\246"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=4181584, ...}) = 0
old_mmap(NULL, 727004, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40432000
mprotect(0x404ca000, 104412, PROT_NONE) = 0
old_mmap(0x404ca000, 86016, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x98000) = 0x404ca000
old_mmap(0x404df000, 18396, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x404df000
close(3)                                = 0
open("/usr/local/grass5/lib/libgcc_s.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libgcc_s.so.1", O_RDONLY)    = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\10\23\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=854160, ...}) = 0
old_mmap(NULL, 32288, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404e4000
mprotect(0x404eb000, 3616, PROT_NONE)   = 0
old_mmap(0x404eb000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x7000) = 0x404eb000
close(3)                                = 0
open("/usr/local/grass5/lib/libssl.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libssl.so.2", O_RDONLY)      = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\340\220"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=224997, ...}) = 0
old_mmap(NULL, 195044, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x404ec000
mprotect(0x40519000, 10724, PROT_NONE)  = 0
old_mmap(0x40519000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2d000) = 0x40519000
close(3)                                = 0
open("/usr/local/grass5/lib/libcrypto.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libcrypto.so.2", O_RDONLY)   = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\00009\2\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=999564, ...}) = 0
old_mmap(NULL, 880612, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x4051c000
mprotect(0x405e4000, 61412, PROT_NONE)  = 0
old_mmap(0x405e4000, 49152, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xc7000) = 0x405e4000
old_mmap(0x405f0000, 12260, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x405f0000
close(3)                                = 0
open("/usr/local/grass5/lib/libkrb5.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/kerberos/lib/libkrb5.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`\360\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=443315, ...}) = 0
old_mmap(NULL, 380508, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x405f3000
mprotect(0x4064e000, 7772, PROT_NONE)   = 0
old_mmap(0x4064e000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5b000) = 0x4064e000
close(3)                                = 0
open("/usr/local/grass5/lib/libk5crypto.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/kerberos/lib/libk5crypto.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\360!\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=77864, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40650000
old_mmap(NULL, 64436, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40651000
mprotect(0x40660000, 2996, PROT_NONE)   = 0
old_mmap(0x40660000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xf000) = 0x40660000
close(3)                                = 0
open("/usr/local/grass5/lib/libcom_err.so.3", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/kerberos/lib/libcom_err.so.3", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`\t\0\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=8966, ...}) = 0
old_mmap(NULL, 4552, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40661000
mprotect(0x40662000, 456, PROT_NONE)    = 0
old_mmap(0x40662000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x40662000
close(3)                                = 0
open("/usr/local/grass5/lib/libcrypt.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libcrypt.so.1", O_RDONLY)    = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\230\t\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=21094, ...}) = 0
old_mmap(NULL, 180860, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40663000
mprotect(0x40668000, 160380, PROT_NONE) = 0
old_mmap(0x40668000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x4000) = 0x40668000
old_mmap(0x40669000, 156284, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x40669000
close(3)                                = 0
open("/usr/local/grass5/lib/libresolv.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libresolv.so.2", O_RDONLY)   = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\270&\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=65191, ...}) = 0
old_mmap(NULL, 65348, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x40690000
mprotect(0x4069d000, 12100, PROT_NONE)  = 0
old_mmap(0x4069d000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd000) = 0x4069d000
old_mmap(0x4069e000, 8004, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4069e000
close(3)                                = 0
open("/usr/local/grass5/lib/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libnsl.so.1", O_RDONLY)      = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\240:\0"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=82857, ...}) = 0
old_mmap(NULL, 81152, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x406a0000
mprotect(0x406b1000, 11520, PROT_NONE)  = 0
old_mmap(0x406b1000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x10000) = 0x406b1000
old_mmap(0x406b2000, 7424, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x406b2000
close(3)                                = 0
open("/usr/local/grass5/lib/libX11.so.6", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/X11R6/lib/libX11.so.6", O_RDONLY) = 3
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@\22\1\000"..., 1024) = 1024
fstat64(3, {st_mode=S_IFREG|0755, st_size=903248, ...}) = 0
old_mmap(NULL, 907292, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x406b4000
mprotect(0x4078f000, 10268, PROT_NONE)  = 0
old_mmap(0x4078f000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xda000) = 0x4078f000
close(3)                                = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40792000
brk(0)                                  = 0x80abd0c
brk(0x80acd0c)                          = 0x80acd0c
brk(0x80ad000)                          = 0x80ad000
open("/home/ben/.grassrc5", O_RDONLY)   = 3
fstat64(3, {st_mode=S_IFREG|0664, st_size=154, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40012000
read(3, "GISDBASE: /home/ben/grass5.0/gra"..., 4096) = 154
read(3, "", 4096)                       = 0
close(3)                                = 0
munmap(0x40012000, 4096)                = 0
access("/home/ben/grass5.0/grass_data_new/virginia", F_OK) = 0
stat64("/home/ben/grass5.0/grass_data_new/virginia/carroll", {st_mode=S_IFDIR|0777, st_size=4096, ...}) = 0
getuid32()                              = 500
geteuid32()                             = 500
getuid32()                              = 500
geteuid32()                             = 500
umask(022)                              = 022
open("/dev/null", O_RDONLY|O_NONBLOCK|O_DIRECTORY) = -1 ENOTDIR (Not a directory)
open("/usr/local/lib", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = 3
fstat64(3, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
fcntl64(3, F_SETFD, FD_CLOEXEC)         = 0
brk(0x80ae000)                          = 0x80ae000
getdents64(0x3, 0x80ac2f8, 0x1000, 0)   = 392
getdents64(0x3, 0x80ac2f8, 0x1000, 0)   = 0
close(3)                                = 0
brk(0x80af000)                          = 0x80af000
stat64("9942CATD.DDF", {st_mode=S_IFREG|0644, st_size=1947, ...}) = 0
open("9942CATD.DDF", O_RDONLY)          = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=1947, ...}) = 0
read(3, "001672L 1 0600049   220400002100"..., 4096) = 1947
_llseek(3, 0, [0], SEEK_SET)            = 0
brk(0x80b0000)                          = 0x80b0000
open("9942CATD.DDF/hdr.adf", O_RDONLY)  = -1 ENOTDIR (Not a directory)
open("9942CATD.DDF/HDR.ADF", O_RDONLY)  = -1 ENOTDIR (Not a directory)
open("9942CATD.DDF", O_RDONLY)          = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=1947, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40013000
read(4, "001672L 1 0600049   220400002100"..., 4096) = 1947
_llseek(4, -1780, [167], SEEK_CUR)      = 0
read(4, "00091 D 1   00039   21040001080C"..., 4096) = 1780
open("./9942IDEN.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942IREF.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942XREF.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DDSH.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DDOM.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DQHL.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DQPA.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DQAA.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DQLC.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DQCG.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942RSDF.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942LDEF.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942CATD.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942CATS.DDF", O_RDONLY)        = 5
close(5)                                = 0
brk(0x80b1000)                          = 0x80b1000
open("./9942STAT.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942DDDF.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942SPDM.DDF", O_RDONLY)        = 5
close(5)                                = 0
open("./9942CEL0.DDF", O_RDONLY)        = 5
close(5)                                = 0
read(4, "", 4096)                       = 0
close(4)                                = 0
munmap(0x40013000, 4096)                = 0
open("./9942IREF.DDF", O_RDONLY)        = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=358, ...}) = 0
read(4, "002072L 1 0600052   320400000210"..., 4096) = 358
_llseek(4, -151, [207], SEEK_CUR)       = 0
read(4, "00151 D 1   00041   310400010080"..., 4096) = 151
close(4)                                = 0
open("./9942XREF.DDF", O_RDONLY)        = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=515, ...}) = 0
read(4, "002332L 1 0600061   230400002100"..., 4096) = 515
_llseek(4, -282, [233], SEEK_CUR)       = 0
read(4, "00282 D 1   00055   330400010080"..., 4096) = 282
close(4)                                = 0
open("./9942LDEF.DDF", O_RDONLY)        = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=288, ...}) = 0
read(4, "001962L 1 0600049   220400002100"..., 4096) = 288
_llseek(4, -92, [196], SEEK_CUR)        = 0
read(4, "00092 D 1   00039   21040001080L"..., 4096) = 92
close(4)                                = 0
open("./9942RSDF.DDF", O_RDONLY)        = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=530, ...}) = 0
read(4, "003512L 1 0600085   330400000210"..., 4096) = 530
_llseek(4, -179, [351], SEEK_CUR)       = 0
read(4, "00179 D 1   00070   230400010800"..., 4096) = 179
close(4)                                = 0
open("./9942DDSH.DDF", O_RDONLY)        = 4
fstat64(4, {st_mode=S_IFREG|0644, st_size=290, ...}) = 0
read(4, "001832L 1 0600049   220400002100"..., 4096) = 290
_llseek(4, -107, [183], SEEK_CUR)       = 0
read(4, "00107 D 1   00039   21040001080D"..., 4096) = 107
fstat64(5, {st_mode=S_IFREG|0644, st_size=6277826, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40014000
read(5, "001882L 1 0600057   220400002100"..., 4096) = 4096
_llseek(5, -3908, [188], SEEK_CUR)      = 0
close(4)                                = 0
brk(0x80b2000)                          = 0x80b2000
close(3)                                = 0
open("/usr/local/grass5/etc/projections", O_RDONLY) = 3
fstat64(3, {st_mode=S_IFREG|0644, st_size=2961, ...}) = 0
read(3, "ll:Lat/Lon\nutm:Universe Transver"..., 4096) = 2961
brk(0x80b3000)                          = 0x80b3000
close(3)                                = 0
--- SIGSEGV (Segmentation fault) ---
+++ killed by SIGSEGV +++
