[GRASSLIST:5660] Re: arrow keys not working
Wayne Gibson
gibson at coas.oregonstate.edu
Mon Feb 24 18:54:07 EST 2003
Glynn,
That did the trick. Thanks.
Wayne Gibson
>From: Glynn Clements <glynn.clements at virgin.net>
>MIME-Version: 1.0
>Content-Transfer-Encoding: 7bit
>To: Wayne Gibson <gibson at coas.oregonstate.edu>
>Cc: grasslist at baylor.edu
>Subject: [GRASSLIST:5659] Re: arrow keys not working
>X-IMID: elron.baylor.edu
>X-OriginalArrivalTime: 24 Feb 2003 21:34:04.0784 (UTC)
FILETIME=[745F8F00:01C2DC4C]
>X-Listprocessor-Version: 8.2.10/991025/16:55 -- ListProc(tm) by CREN
>Wayne Gibson wrote:
>> I compared the libraries required by "set_data" in the 5.0.0 pre-compiled
>> version and 5.0.1 that I compiled. The pre-compiled uses both libncurses and
>> libcurses while the version I compiled uses libncurses only. It that what
one
>> should expect? (5.0.0 "set_data" works)
>I've figured out what's happening.
>Short version: add:
> #include "config.h"
>to the top of src/libes/vask/V_init.c and re-compile (the problem is
>in a library, so I suggest compiling from scratch).
>Long version:
>1. 5.0.0 didn't have the test for HAVE_KEYPAD; it always used
>keypad(), which resulted in a compilation failure on systems where
>the curses library didn't have the keypad() function.
>2. 5.0.1 has the keypad() check in configure, and HAVE_KEYPAD in
>src/include/config.h[.in], and the use of keypad() is conditionalised
>upon HAVE_KEYPAD. Unfortunately, the source file neglected to actually
>include config.h, so keypad() was never used and the cursor keys won't
>work.
>3. The problem is fixed in the current CVS versions (both HEAD and the
>release branch from which 5.0.2 will be built); actually, the problem
>had already been fixed in the CVS HEAD when 5.0.1 was released, but it
>hadn't been merged into the release branch at that point.
Wayne Gibson
Oregon State University
(541) 737-5696
