[GRASSLIST:5258] Re: MrSID file import into GRASS and ... ?
Eric G. Miller
egm2 at jps.net
Wed Jan 1 18:44:51 EST 2003
On Wed, Jan 01, 2003 at 06:21:22PM -0500, Allen Wilkinson wrote:
> I am trying to get some DOQQ files of Ohio to import into GRASS. All I
> find for free is MrSID files. Does or will GRASS support MrSID files?
The MrSID format uses a patented compression algorithm, so it will
likely never be supported.
> If not, does nayone know of GeoTiff DOQQ ifles for Ohio?
You can get the original data from USGS, but it'll cost. Benefit is,
the data wouldn't have lost information due to MrSID compression (which
is lossy).
"...the plural of anecdote is [not?] data." - attrib. to George Stigler
